i Have a Turboed VRX and need some questions answered :D
shaunyork26
Postby shaunyork26 » Tue Nov 24, 2015 4:12 pm
Real first name: shaun
Model: 13my vrx
Colour:white
General interests:CARS haha
Current mods: well, where do i begin, curently running a evo x turbo setup on 8 pound making 160atw kw at 558nm of torque. lots more haha
Planned mods: boost tee and too run a 10psi
How you found out about ClubCJ: aus cj
shaunyork26
Postby shaunyork26 » Tue Nov 24, 2015 4:16 pm
Need to ruffly know what sort of figures the rods can hold.
merlin
Postby merlin » Tue Nov 24, 2015 5:11 pm
The 4B11 engine seems to be good for 14psi on the stock EvoX wastegate.
Dont know about the 4B12.
What ROM are you running?
Postby Lancer1993 » Tue Nov 24, 2015 5:58 pm
Sounds interesting, how is the FWD handle with that much power, any torque steer or other issues with not having AWD?
D
Postby D » Tue Nov 24, 2015 7:43 pm
(WTTC)
ROTM WINNER SEPT 2014
LiX
Postby LiX » Wed Nov 25, 2015 5:28 am
Hmmm 558 Nm seems veeery high for your application at that boost level.
Just for reference my turboed 4B10 at 11 psi makes around 300 Nm.
Rods are good for 14 psi of boost, however you will have to reduce the static CR by using a ticker head gasket. Evo X cams are also recommended.
merlin
Postby merlin » Wed Nov 25, 2015 2:52 pm
Just use an Evo head gasket.
LiX
Postby LiX » Thu Nov 26, 2015 2:59 am
merlin wrote:Just use an Evo head gasket.
There are better aftermarket alternatives than OEM X head gasket.
Lancer head gasket is 2 layer 0.4 mm, OEM X gasket is 1.0 mm.
Good alternative is the Cosworth 5 layer 1.3 mm head gasket.
Users browsing this forum: Google [Bot] and 34 guests
