Hey guys i have water marks on my car well majority of the water marks are on the bonnet
Anyone have a quick way to get rid of them?
I'm washing the car tomorrow so I just want to know a good efficient way to remove the water spots
My cars white btw [/img][/youtube]
Water marks/spots on car
I hear if you mix some metho with your car wash mix it helps reduce/prevent water spots
ROTM WINNER SEPT 2014
It depends how bad they are, normally if t=you give a quick detail with some thing like McGuire waterless detail will remove them.
The secret it to dry it straight after it gets wet.
If they are too bad then a fine cut and polish will do the trick. after they are removed use a paint protector to prevent it happening again.
- Shaun Patterson
