	Gearchange from 5th gear problem
- Miss Wendy
Hi all,  I was wondering if anyone has had trouble with manual gearbox change from 5th gear back to 4th and 3rd. When travelling uphill  in 5th, I cannot select 4th or 3rd gear.  I have to either go back to 5th gear, which almost stalls due to lack of speed or have to try to force/crunch it into 2nd gear. Had it back to Kelly Mitsubishi at Cardiff NSW, but they are unable to fault it. They said they have adjusted a few things and changed gearbox oil, which has made no difference. This problem doesn't always occur,(usually when engine cold or when travelled in 5th gear for long periods ie out on open roads coming back into traffic),  but I am worried another car is going rear end the lancer as it almost comes to a halt until I can get a gear.
						- ChrisRalliart09
Sounds like a real pain, I probably wouldn't take it back to Kelly Mitsubishi and get someone else to look at it. If they find something can take it back to Kelly and show them where they may have made a mistake and fix it at their expense. Do you have any mods? Depending on the age of your car most things should still be under warranty.
									BC Racing Coilovers, 3in Turbo back Exhaust, Merlin Tune.
Once you go black, your endlessly cleaning that.
- Miss Wendy
Miss Wendy wrote:Lancer is still under warranty. With regard to taking it to Klosters....I have had mixed feedback about their service..I suppose weighing it up..Kellys havent been of much use anyhow. It hasnt had any mods done to the gearbox.
Give it a go - best that will happen is they find and fix problem during warranty.
Worst that will happen is they won't find the problem.
- Miss Wendy
Re: Gearchange from 5th gear problem
Well....this week a brand new gearbox arrived from Mitsubishi and was fitted under warranty.  Kellys found metal shavings in the gearbox oil. When gearbox was dismantled they found that 3rd and 5th gear syncros were pitted.  Car back on road and very happy...Thankyou to Kellys
Good job.  How many km's did your car do before the gearbox packed it in?
						- Miss Wendy
127000 K's.  On the last day of warranty.
Miss Wendy wrote:127000 K's. On the last day of warranty.
Hahahahahaha the last day! that is awesome!
Merlinised
Hi mate I have trouble downshifting into 3rd, have you had a solution your gearbox problem?
tonee wrote:Hi mate I have trouble downshifting into 3rd, have you had a solution your gearbox problem?
Not sure Wendy will reply as she hasn't logged on for 14 months.
