Replacement Fuel Filter?
cammag5
Postby cammag5 » Sat Aug 27, 2016 9:44 am
Anyone have the part number for fuel filter and is it the same for 4B11 and 4B12?
cammag5
Re: Replacement Fuel Filter?
Postby cammag5 » Sat Aug 27, 2016 4:30 pm
bump
Dannn
Postby Dannn » Sat Aug 27, 2016 4:55 pm
Merlinised
Kal777
Postby Kal777 » Sat Aug 27, 2016 5:59 pm
Ryco Z924, it's a intake fuel filter module meaning it holds the pump, float and filter all in one. The pump and float come off the original and are transplanted into the new.
Have installed this into a 4b11, 4b12 has the same tank and pump so should be the same but can not confirm 100%
sarusa
Postby sarusa » Mon Aug 29, 2016 10:55 am
The use of the word "intake" in this context seams confusing! Or is there a second fuel filter as well?
Postby lancerdarryl » Mon Aug 29, 2016 12:43 pm
sarusa wrote:The use of the word "intake" in this context seams confusing! Or is there a second fuel filter as well?
That would be a suction filter I would say.
CJsportback
Postby CJsportback » Mon Aug 29, 2016 1:05 pm
I'm sure Kal meant to say 'in-tank'.
sarusa
Postby sarusa » Mon Aug 29, 2016 2:57 pm
CJsportback wrote:I'm sure Kal meant to say 'in-tank'.
Recon your right! :D
Kal777
Postby Kal777 » Mon Aug 29, 2016 5:42 pm
Correct. You can thank android for changing "in-take" to intake.
CJsportback
Postby CJsportback » Mon Aug 29, 2016 6:57 pm
And again :P
sarusa
Postby sarusa » Tue Aug 30, 2016 9:44 am
Simplified, word should be in-tank not in-take, tank, not take! Haha
Postby Lancer1993 » Tue Aug 30, 2016 4:01 pm
So it's not only my iPhone's auto correct that screws up :)
jcmedinaceli
Postby jcmedinaceli » Fri Sep 02, 2016 11:54 pm
There is a new tutorial on youtube to do this replacement
https://youtu.be/ODUKe2Zrf-Q
benyamin
Postby benyamin » Mon Feb 26, 2018 11:38 am
I looked at some of the YouTube University tutorials for both filter and pump replacement, and all the ones I looked at were missing the proper safety procedure and spilt fuel everywhere. :shock: Also many of them used the wrong sort of line clamps which would have damaged the fuel line(s) (I'd only ever use plugs anyway), and none that I watched covered or plugged the hole whilst working on the sub-assembly to prevent the ingress of contaminants.
Even a basic read of the shop manual and most of these mistakes could have been prevented. I'm thinking a How-To might be in order, especially now that the model is ageing. I'm definitely going to be replacing my filter and maybe the pump too, so perhaps this is a good opportunity to write something up.
*ranger*
Anyway, as far as parts go, the Ryco filter catalogue is a bit messy for the CJs. From what I can tell the right parts are as follows:
  1. The 4B11 & 4B12 (as Kal777 pointed out) use the Z924
  2. The 4B11T uses the Z991
I did notice however, that some tuners list a filter upgrade for the 4B11T, so there might be a better one...
Postby lancerdarryl » Mon Feb 26, 2018 5:47 pm
Z991 is a twin pipe delivery. Have a look on the Ryco filter website they have photos of their products. Dual fuel pumps ?
Return to “Maintenance”
Users browsing this forum: Google [Bot] and 25 guests
