Headlight wiring loom
Hey guys,
Just wondering if anyone knows what the extra plug on the headlight wiring loom is used for. There the the main harness plug with the orange internals which controls indicator, hi/low beams etc, but i cant figure out what this 2nd plug is.
I have just replaced my headlights, new ones have an accessory wire for DRL. And just wondering whether this plug controlled the crappy led on the oem headlights.
Will add a photo later (too large from phone so need to adjust sizing.)
Re: Headlight wiring loom
Model and year may help too.
2nd plug is used in the factory HID lights,it controls the turning motor and the self levelling motor.
Very handy to know. Thanks for the info
Before i go testing, does anyone know if these are constant or switched power? Having aftermarket headlights and never having the leveling motors i dont really need the oem leveling motor cabling anymore ... but would like it to power my DRL if possible. If its constant from engine on they make lige a lot easier
- Ronan.Butler11
lancerdarryl wrote:2nd plug is used in the factory HID lights,it controls the turning motor and the self levelling motor.
wait... there is a HID loom in the CJ's already?? meaning plug and play for any projectors?
or am i completely misunderstanding this
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
The plugs may be there but probably don't work.There will be relays missing and additional wiring looms inside the car missing also.
Unsure, asking the company i purchased from for confirmation. I dont see why not, they arent HID/LED conversions for headlights only projector conversion ... still using halogen globes (for now, til i can source some 'legal' conversion kits), and the DRL is ccfl not LED so again ... doesnt require automatic leveling/cleaning like hid/led DRL lights.
If they are ADR compliance then its a mod i would certainly consider down the track for sure. Can i trouble you please for info on where to purchase these.
Thanks
Thanks
bumblebee wrote:If they are ADR compliance then its a mod i would certainly consider down the track for sure. Can i trouble you please for info on where to purchase these.
Thanks
http://www.ebay.com.au/itm/232152444777
Or direct from supplier page
http://www.ctautoparts.com.au/3d-neon-l ... ion-x.html
Pretty sure it is
We ve sold more than 100 sets all over differs state
Never had any issue
Best regards,
CT Autoparts Pty. Ltd. Australia
Unit 14/ 367-369 Victoria Street, Wetherill Park 2164, Sydney, NSW , Australia
Tel: +61-2-9756 0138
Mob: +61 -405 924 864
Website: www.ctautoparts.com.au
Response from the guys that sold it. I will update if i find out otherwise
"Pretty sure it is".....that says to me they aren't ADR compliant.If they were then the answer would have been "Yes".
- Shaun Patterson
there is no LEGAL hid conversion kits, for HID to be legal you need autoleveling projectors and headlight washers,, the leveeling is also impossible to retrofit and require so man gyros and sensors
