Lancer1993 wrote:lancer2014 - whats that under the rear?
A lower control arm upgrade kit, some replace the subframe also.
Damir wrote:a guard roll for the rears is a must. you might struggle fitting the meisters as they are wide and a moderately aggressive offset.
if you plan to splash out then try and get some rear camber arms (megan racing are the most commonly used around here) and lower the car quite a bit to achieve some natural camber as well.
the d9r with +38 offset will be fine with just a roll
ReidVR wrote:Hey guys, I’m looking at getting a second hand set of Avid Av-01’s, sized 18x9.5 +35 with stretched 225/40r18‘s. will these fit on my 2009 VR sedan? Cheers
ReidVR wrote:Cheers Ronan, ahh alright, I was looking to go for 18x8’s but this is too good of a deal! $850 for the set, and perfect condition. But I guess I’ll hve to keep looking
