Dumb question but is there a tow kit for the RA (sedan or sportback)
also had anyone found a tow bar option with a square mount for quicker removal and not just the flat one with 2 bolts?
	Tow bar wiring
Re: Tow bar wiring
Lancer1993 wrote:Dumb question but is there a tow kit for the RA (sedan or sportback)
you won't get one for the lancer, the square hitch is used for heavy duty towing and allows for the fitting of a weight distributing hitch. anything rated up to 1250kg will only come with a flat tongue.
Re: Tow bar wiring
Which is annoying as I've see other new small cars with them, Corolla, i30, Golf just to name a few.
The i30 one looked factory with a Hyundai logo on the plate you put in the square hole when not using the tow hitch.
Re: Tow bar wiring
When the Ralliart first came out there wasn't a towbar option available for them due to the hydraulic pump in the right hand rear corner of the car.There may be one available now but I seriously think you wouldn't get a non-genuine one.
Re: Tow bar wiring
Lancer1993 wrote:Which is annoying as I've see other new small cars with them, Corolla, i30, Golf just to name a few.
the Lancer's maximum towing capacity is 1000kg vs the i30 which can tow 1300kg so there's a fair bit of difference there.
Re: Tow bar wiring
Not sure if Mitsubishi still sells a genuine tow bar package, might have to look into this before making the move to a RA.
Its annoying the CJ Lancer has just the 1000kg limit compared to other small cars.
- Quismiff
Re: Tow bar wiring
Lancer1993 wrote:Not sure if Mitsubishi still sells a genuine tow bar package, might have to look into this before making the move to a RA.
Constraints of the chassis design, maybe some rear body work on the flanges around where the drawbar mounts, and then some rear suspension work, uprated shocks etc, and you might be able to certify it for 1500, but not much more. There will be engineering reasons that they designed this chassis to be an interchangeable platform. So it was quick to turn out.
Mitsubishi
2006–2012 Mitsubishi Outlander
2007–2017 Mitsubishi Lancer (sedan, hatchback)
2007–present Mitsubishi Delica
2008–present Mitsubishi Racing Lancer
2010–present Mitsubishi RVR (GA3W) (aka Mitsubishi ASX/Outlander Sport)
2017–present Mitsubishi Grand Lancer
2017–present Mitsubishi Eclipse Cross
Chrysler/Fiat
2007–2012 Dodge Caliber hatchback (PM)
2007–2016 Jeep Compass sports wagon (MK)
2007–2017 Jeep Patriot crossover SUV (MK)
2008–2013 Dodge Avenger (JS)
2009–present Dodge Journey / Fiat Freemont (JC49)
2007–2010 Chrysler Sebring sedan (JS)
2008–2010 Chrysler Sebring Convertible (JS)
2011–2014 Chrysler 200 sedan & convertible (JS)
PSA
2007–2012 Citroën C-Crosser/Peugeot 4007
2012-present Citroën C4 Aircross/Peugeot 4008
Proton
2010–2015 Proton Inspira
2007 MY08 VR-X
Re: Tow bar wiring
Not saying I'd want to tow heavy load, just it would be nice to have the square hitch option for convenience.
Did a quick look and some do offer a tow bar solution for the RA, but I'll have to go into it further and make some calls and the info might be out of date and no longer available for the CJ.
