hi all..hope i can learn from you guys... - shaft
Postby aspir3 » Fri Sep 09, 2011 3:34 pm
You do not need the Mitsubishi adaptor. The Tactrix cable is all you need. It comes with a USB/mini USB cable as well, but these are available any where.
shaft
Postby shaft » Fri Apr 20, 2012 5:35 pm
thanks..sorry for long absence
i've received the cables quite sometime a go and only now got time to play with it.. :lol:
i guess ill do a new thread on the progress of my slow quest... 8)
shaft
telec90
Re: hi all..hope i can learn from you guys... - shaft
Postby telec90 » Fri Jun 21, 2019 10:35 pm
That is a little bit short discussion as for me. I haven't met with such a problem (and that is good) but if I have I would short on time I would use the best essay help https://essayyoda.com/best-essay-help/ for example. I am really glad to see that I could ask people at this forum and get a free answer. If anything would go this way.....
