	You know you drive a CJ when...
Re: You know you drive a CJ when...
You upgrade the wiring to the fuel pump and get an error pop up on the instrument cluster
Sigh
Thankfully it lasted all of about 1 minute and then cleared itself
Phew!
									Sigh
Phew!
- Quismiff
ASC warning pops up pulling away from the lights
									2007 MY08 VR-X
Check your speed sensors
- Quismiff
bumblebee wrote:Check your speed sensors
No, it's a right peddle actuation problem, and it was the shite tyres, got 225 kuhmos now, much stickier =)
2007 MY08 VR-X
You know you drive a CJ when you need to replace the air in the tie-yas in winter time
http://imgur.com/a/CEYhPZh
You got to change out your blinker fluid before summer arrives. Can't be too careful. Don't want nothing to short out. Remember.
Safety First!
http://imgur.com/a/HMFaFQE
									Safety First!
You need to cover up your ride so nobody wants to steal it cos everyone thinks its an Evo
http://imgur.com/a/3qj8lwI
- Ronan.Butler11
when traction control starts screwing you about when you pull onto a main road and give it some. my god i hate it
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
						'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
There is a fix for that . Drop in a Quaife ATB LSD then modify the ETACS box and tell it you have a helical LSD. Solved
- Ronan.Butler11
bumblebee wrote:There is a fix for that . Drop in a Quaife ATB LSD then modify the ETACS box and tell it you have a helical LSD. Solved
i just bought another car. problem solved hahaha
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
						'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Does the new car have an open differential?
- Ronan.Butler11
well it used to have active yaw control, then the prev. owner swapped it out for a magna rear diff because it kept blowing up on him. have reciepts for 5k over 2 years for repairs hahaha
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
						'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
LOL
