Center Console Buttons
mrlancealot
Postby mrlancealot » Thu Sep 19, 2019 4:59 pm
Hi everyone,
I want to put some some switches/buttons on the center console where my coin box currently is atm.
And I've got some questions.
1. What is the part called that houses the buttons (in place of the coin box)?
2. What is this blank space used for?
https://imgur.com/a/328SkkA
* Adj Strut Bar
* K&N Air Panel filter
Re: Center Console Buttons
Postby bumblebee » Thu Sep 19, 2019 6:14 pm
Centre console is it's name
Postby Lancer1993 » Thu Sep 19, 2019 7:50 pm
#2 is for heated seats on some models.
Here is the panel switch part number to replace the coin holder.
You can put some USB Power or spot light switches in them.
Postby bumblebee » Thu Sep 19, 2019 9:27 pm
Truckloads of different switches for these
Can also drop in a switch for a front camera also
Have a look thru AliExpress
Search on Mitsubishi switch
mrlancealot
Postby mrlancealot » Fri Sep 20, 2019 12:17 am
@Lancer1993 Perfect. Thanks!
* Adj Strut Bar
mrlancealot
Postby mrlancealot » Fri Sep 20, 2019 12:10 pm
@bumblebee I try not to use Ali express (I don't have an account yet). But yes, there does seem like Ali has 100x more mitsu switches than ebay. I'm not certain I need I all the different types though.
* Adj Strut Bar
Postby Lancer1993 » Fri Sep 20, 2019 5:18 pm
That switch panel is not overly expensive but I think it was like $20 at the dealer, which is costly for a little bit of plastic.
The switches you buy really depends on what you want to put down there.
VRXblack
Postby VRXblack » Sat Sep 21, 2019 2:29 pm
Panel and 2 fake buttons cost me $26 from amayama.
Black 2010 VRX Lancer
Sam101
Postby Sam101 » Sun Sep 22, 2019 12:31 pm
I pulled out the centre console coin holder, and there's some wires taped underneath. Are these for optional usb power? Is it possible to just plug and play the switches/usb connections? 2017 lancer es
Postby Lancer1993 » Sun Sep 22, 2019 5:06 pm
They are for options your ES might not have, the wiring harness in the CJ is the same as the RA and EVO,
My 09 VRX has some wires there also.
adamhumphrey
Postby adamhumphrey » Sun Sep 22, 2019 5:09 pm
Sam101 wrote:I pulled out the centre console coin holder, and there's some wires taped underneath. Are these for optional usb power? Is it possible to just plug and play the switches/usb connections? 2017 lancer es
These wires may be for higher models i.e the Evo.
Here is what is hooked up there in my 2010 Evo X MR - Afs lighting control and Awc Control. Centre is an aftermarket Tyre Pressure Monitor so ignore that.
mrlancealot wrote:Hi everyone,
Number two in the picture is the heated seating buttons
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
Postby bumblebee » Sun Sep 22, 2019 9:13 pm
NA lancers don't have heated seats
They have ejection seats
Postby Lancer1993 » Mon Sep 23, 2019 11:56 am
LOL that goes nicely with the FluxCapacitor I have under the bonnet!
mrlancealot
Postby mrlancealot » Mon Sep 23, 2019 1:14 pm
Thanks all for the photos and prices. It's helpful for all of us with lower specced models.
I think I might put a voltmeter switch next to my "Ejection Seat" switch
* Adj Strut Bar
Postby Lancer1993 » Mon Sep 23, 2019 3:11 pm
Should have postered this earlier but...
this is mine, the right on is the turn the power off to the front camera, the middle is a couple of USB ports with volt meter (AliExpress) The left is a garage opener, shy don't tell anyone.
Return to “Interior”
