I have the copyright on it
So there
adamhumphrey wrote:Sam101 wrote:I pulled out the centre console coin holder, and there's some wires taped underneath. Are these for optional usb power? Is it possible to just plug and play the switches/usb connections? 2017 lancer es
These wires may be for higher models i.e the Evo.
Here is what is hooked up there in my 2010 Evo X MR - Afs lighting control and Awc Control. Centre is an aftermarket Tyre Pressure Monitor so ignore that.
IMG_2179.jpgmrlancealot wrote:Hi everyone,
I want to put some some switches/buttons on the center console where my coin box currently is atm.
And I've got some questions.
1. What is the part called that houses the buttons (in place of the coin box)?
2. What is this blank space used for?
https://imgur.com/a/328SkkA
Number two in the picture is the heated seating buttons
Should have postered this earlier but...
this is mine, the right on is the turn the power off to the front camera, the middle is a couple of USB ports with volt meter (AliExpress) The left is a garage opener, shy don't tell anyone.
You can't put in an ejection seat function
I'll send a photo off when I finish all these essays :/
mrlancealot wrote:Should have postered this earlier but...
Nice. When you say front camera, do you mean dashcam? I'm assuming you've tapped into the "always on" 12V and you switch it on when driving and maybe at the parking lot.
Garage opener is handy. I would too if I had an automatic garage door.
The camera runs into the 2nd AUX in my Android HU
mrlancealot wrote:You can't put in an ejection seat function
Buggers. I'll have to post back the ejection seats to my ebay seller. Luckily I have ebay plus.
