I have done the obvious and put in a fresh battery but that hasn't solved anything.
Any idea what could be causing the problem?
I have this style key
bumblebee wrote:In other words, a locksmith cos a decent one will have a MUT3 or similar and can program it to the ETACS box
dopey wrote:Does the LED light up when you press a button and does the car start with the fob?
Werribee wrote:dopey wrote:Does the LED light up when you press a button and does the car start with the fob?
Nope nothing.
dopey wrote:Werribee wrote:dopey wrote:Does the LED light up when you press a button and does the car start with the fob?
Nope nothing.
Sounds like the actual fob, either it's dead or not getting power. I'd try the battery from the good remote first. If there's still no life then remove the cover again and press on the buttons for the guts of the remote to drop down. Separate the board from the black frame and check if the contacts from the battery have become loose and maybe bend them slightly for better contact and see how you go.
dopey wrote:does the car start with that fob?
