Not a bad video
It was funny watching it cos I knew most.of the roads he was on, I'm sure I have seen that car around a few times.
Anyhoo
Looks like.you got this all under control.
Keep us posted
	Looking at a 2013 Ralliart Lancer
Re: Looking at a 2013 Ralliart Lancer
- schoolofmonkey
bumblebee wrote:Not a bad video
Anyhoo
Keep us posted
Will do, can't thank you and everyone else who's helped out enough.
If they give me print out from the Dyno, I'll show post it for you
Just remember , dyno chart don't mean much, you can doctor those.up to say what ever you want
Having said that , if you have a decent OBD2 tool and say "dash Commander" on your phone you can do assorted tests like that with it. There is a also a "virtual dyno" application.you can get that I have found to be pretty reliable as.well
And the best tell tale sign of performance is none other then the drag strip
If you can make it to a test and tune night before and after the mods and keep your slips then you will see if there is any gain's.
- schoolofmonkey
bumblebee wrote:Just remember , dyno chart don't mean much, you can doctor those.up to say what ever you want
Will look into that, I'll ask some of the local QLD guys.
I'm currently a little unsure of the E85 conversion, there's only 3c difference between E85 and U98, but I'm going to use more E85 in the long run.
Guess that's the benefits of the ability to run both without having to drain the tank.
Don't forget E85 gives.you more power then 98 any day of the week
Give it 2 weeks and 98 will be almost $2 again
E85 is quite good I found round town and the highway
Rather E85 then 98 any day
Not only is it cheaper
More power
Less knock
Also better for the environment
And best of all
It smells so damn good
More power
Less knock
And best of all
- schoolofmonkey
bumblebee wrote:Don't forget E85 gives.you more power then 98 any day of the week
More power
Less knock
And best of all
You're right, at the end of the day I've had to fill up 3 times this wee, on day U98 was 1.79L.
I'm over thinking it
