Spoiler for 2010 CJ Lancer
DamnRanga
Postby DamnRanga » Fri May 15, 2020 7:28 pm
Hi Everyone,
I have recently decided that i would like to put a spoiler on my 2010 CJ Lancer.
Currently I have the Activ spoiler on but i would like to replace that with either the APR GTC-200 or the replica Evo X spoiler
I am unsure as whether these would fit directly on or whether i would have to drill new holes.
I would prefer not to have to drill new holes as I am afraid i will screw up and have a hole in my boot i dont need.
It would be much appreciated if someone has either of these spoilers and could let me know if they fit.
Thanks!
Re: Spoiler for 2010 CJ Lancer
Postby bumblebee » Fri May 15, 2020 8:25 pm
I have swapped out my Activ wing with a Ralliart and it's a direct fit
Even if you have to drill a hole
Use a piece of thib card board as a template on the new wing and then drill the hole
The Evo X wing from memory had a plastic clip on it that could be cut off if needed
I did that to the RA
Been on for a few years now
No drama
Have a look thru the forum
I chopped a hole in the boot lid one inch square to fit an OEM reverse camera cover
Use the same principle I did to mark the holes to drill in the boot.
Where are you located?
Someone maybe close by to help out
lancer2014
Postby lancer2014 » Sat May 16, 2020 12:32 pm
I have installed the evo x replica and the screws fitted into the original holes
evo x turbo kit
RRM crank pulley
Magnaflow cat back 2.5
Tein Flex Z Coilovers
Avid 1- 06 18 x 8.5 x 35et
Postby bumblebee » Sat May 16, 2020 2:02 pm
The template for the RA, Evo X , Activ wing where they bolt to is all the same
YAY!
DamnRanga
Postby DamnRanga » Sun May 17, 2020 9:32 am
Thanks for the help everyone!
I'm still currently looking for a cheap evo x spoiler that fits the es but they all seem to cost so much.
The cheapest i could find was about $215 but they have been out of stock for a while.
The next closest place is bodykit kingdom to me and they have one for $415.
i would not like to spend that much on one but am unsure where to look.
One again thanks everyone for the help you have already given me!
Postby bumblebee » Sun May 17, 2020 11:27 am
Once you buy a new wing don't be surprised if you need to paint it
Have a chat to Jimmy at evolution racing spares in Sydney, he is bound to have one off a wreck already painted and ready to roll
