	Gear stick vrx
Gear stick vrx
So this is a really random question, I'm wondering if the gear stick in the 2008 vrx can unscrew, I might just be weak, but I also don't want to break it by trying to hard.
						Re: Gear stick vrx
Gear stick or gear knob?
Yes the OEM manual gear knob does unscrew , turn it left to undo.
However . if it is an aftermarket knob it may have three tiny grub screws around the bottom edge you need to loosen then pull straight up.
Re: Gear stick vrx
The stock VRX shift knob can definitely unscrew as Awood said.
Just hijacking the topic slightly, my leather gear knob has worn down to hell and back, does anyone have suggestions for any aftermarket knobs they've used?
I'd love something as similar to the Evo knob but they go for close to $200 online, so wanted to get some others' ideas.
2011 VRX Sportback
If in doubt, rev it out!
Re: Gear stick vrx
The gear stick is mounted under the centre console and is usually fairly sturdy
However
The centre console comes out fairly easily
The gear knob in the manual will unscrew
In some of the CVT the gear knob will unscrew and some of the CVT the gear knob need to unclip and lift up
There was a document explaining the CVT removal on this forum sometime ago
									However
Re: Gear stick vrx
Re: Gear stick vrx
Thank you so much, I'll give it a go and see what I can do
						Re: Gear stick vrx
awesome
- adamhumphrey
Re: Gear stick vrx
When I had my wife's vrx I ordered an oem polished alloy gear knob from the U.S looked mint. Saved heaps of dollars over buying it here too.
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
- adamhumphrey
Re: Gear stick vrx
Gear knob normal Lancer one.
https://www.mitsubishipartswarehouse.com/oem-parts/mitsubishi-shift-knob-manual-transmission-mz360280ex?c=Zz1pbnRlcmlvciZzPWxldmVyJmw9NSZuPVNlYXJjaCBSZXN1bHRzJmE9bWl0c3ViaXNoaSZvPWxhbmNlciZ5PTIwMDgmdD1lcyZlPTItMGwtbDQtZ2Fz
They also have an evo X one on there too
https://www.mitsubishipartswarehouse.com/oem-parts/mitsubishi-evo-shift-knob-last-one-free-shipping-mz525635ex?c=Zz1pbnRlcmlvciZzPWxldmVyJmw9MSZuPVNlYXJjaCBSZXN1bHRzJmE9bWl0c3ViaXNoaSZvPWxhbmNlciZ5PTIwMDgmdD1lcyZlPTItMGwtbDQtZ2Fz
Parking Brake grip V1
https://www.mitsubishipartswarehouse.com/oem-parts/mitsubishi-parking-brake-grip-mz360282ex?c=Zz1pbnRlcmlvciZzPWxldmVyJmw9MyZuPVNlYXJjaCBSZXN1bHRzJmE9bWl0c3ViaXNoaSZvPWxhbmNlciZ5PTIwMDgmdD1lcyZlPTItMGwtbDQtZ2Fz
Parking grip V2 With leather
https://www.mitsubishipartswarehouse.com/oem-parts/mitsubishi-parking-brake-grip-mz360195ex?c=Zz1pbnRlcmlvciZzPWxldmVyJmw9NiZuPVNlYXJjaCBSZXN1bHRzJmE9bWl0c3ViaXNoaSZvPWxhbmNlciZ5PTIwMDgmdD1lcyZlPTItMGwtbDQtZ2Fz
You may be able to find these cheaper elsewhere, at least you have the part numbers.
Re: Gear stick vrx
Cheers Adam, thanks for the model numbers
									2011 VRX Sportback
Re: Gear stick vrx
Make sure to get the thread pitch right on the aftermarket models
Re: Gear stick vrx
Mine is some Silver looking aftermarket knob that seems to comee loose? I can't seem to find any screws except one right at the top looks like needs all Allen key and then it's just a small screw that is supposed to grip the shaft? So is currently completely loose.....
						Re: Gear stick vrx
It may have been over tighten a few times and now the threads are stuffed
It could be the gear knob itself is stuffed
Know anyone else with a lancer near by you can swap the gear knob with to test ?
Got a wrecker near by you can test with ?
Return to “ClubCJ Member of the Month”
