	Dummy interior button and unplugged cable
Anyone know what the dummy button next to the ASC button do? it has a wire plugged into the dummy button and behind the dummy button there is a large pin plug (24 pin?) and was wondering both could be for
							- Attachments
- dummy button2.jpg (29.49 KiB) Viewed 38835 times
- large plug.jpg (423.98 KiB) Viewed 38835 times
Re: Dummy interior button and unplugged cable
Pretty sure the smaller plug is for remote boot release switch , which you can buy a switch online to plug and play.
Big plug , God knows.
awood wrote:Pretty sure the smaller plug is for remote boot release switch , which you can buy a switch online to plug and play.
ahh but i have a like boot lever at the bottom of the seat so why have two?
JaymeF12 wrote:awood wrote:Pretty sure the smaller plug is for remote boot release switch , which you can buy a switch online to plug and play.
Because , cool.
I'd do this if you could remove the floor one without leaving a hole in the carpet.
						- adamhumphrey
I think the plug could be the manual head light adjustment switch.
https://www.aliexpress.com/item/1005001703554229.html?spm=a2g0o.ppclist.product.2.33ba4wW74wW7gO&pdp_npi=2%40dis%21AUD%21AU%20%2445.38%21AU%20%2439.14%21%21%21%21%21%400b15785416610727421818281e12a2%2112000017219806993%21btf&_t=pvid:98d9920c-ab14-4227-84f9-172ac075e80e&afTraceInfo=1005001703554229__pc__pcBridgePPC__xxxxxx__1661072742
MY11 Evo X MR (2011-Current)
MY20 Asx GSR (2023-Current)
adamhumphrey wrote:I think the plug could be the manual head light adjustment switch.
Are the headlight adjustments specific to a certain headlight? HIDs i think?
- adamhumphrey
I have HID's in my car and the adjustment is auto. I think it applied to some ralliart models. You also need the levelling motors within the headlights.
- adamhumphrey
http://clubcj.net/viewtopic.php?t=18409&start=30
You also have to have the wiring in the plug at the headlight also. This thread talks about it
adamhumphrey wrote:http://clubcj.net/viewtopic.php?t=18409&start=30
I dont think my headlights have that, i just had a quick look and it doesnt look like there is any extra wiring besides the wires for bulbs. Also behind the front bumper, below the hood latch there was this connector and was wondering what this is for?
- Attachments
- FrBuPlug2.jpg (286.39 KiB) Viewed 38711 times
- adamhumphrey
Outside temp sensor I think. Unless its the sensor for bonnet open/close
adamhumphrey wrote:Outside temp sensor I think. Unless its the sensor for bonnet open/close
Would this be for the fog lights actually? because i see the hood latch connector right by the hood release
