Performace chip? real or hoax?
Came across this thing on ebay...
http://cgi.ebay.com/ebaymotors/PERFORMA ... 06.c0.m245
Is this for real or just some hoax guys?
- Josh_Emerton
- Speedie
Basicly how a MAF works is by sending a voltage from the sensor to the computer as air gets colder (denser) the current is increased in turn the ECU adds more fuel to to engine. Hot air decreases the current and in turn reduces the fuel. So the MAF and O2 sensors work together with the ECU to produce the correct Air/Fuel ratio as programmed.
Now those chips are resistors as Sir-VRX has pointed out, a resistor increases the current, So now you have the ECU thinking its getting cooler air.
There are loads of piggy back ECU modules.. I can only speak from my motorcycling experience, with items such as PowerCommander USB III and other mapping units... they do work, but add little power. They aim to either richen or lean areas of your mapping... making the transitions between sectors more smooth. What you get, once you have dyno-ed the bike/car, is a very smooth drive and near lambda AFR throughout the range....
I am not sure if my contribution helped at all !!?!?!?!?
Echo the sentiments of all regarding the magic black boxes out there for $20 etc.. you can richen up your ride, dumbly, by even fooling around with a vehicle's TPS... But then you run the risk of fouling plugs, adding soot to your whole engine and f*ing with your valve train....
My 2c
Tryg
My 2c
Tryg
- Superintendent Chalmers
- Peanut
- Lancer Ralliart
Superintendent Chalmers wrote:I think a Ralliart sticker or badge gives you more HP increase than this "Power upgrade"
Yeah word on the streets is that a GTR badge is good for an extra 40kw ATW lol
Look Out! in The Shire!!
The Can Crusher, Tuckin' Rubber, Pancake Flat. - CCJ Premium Member #0022
bobcrusader wrote:
Blake, you must be a member of the fun police? Do you know my wife?
