The Helicopter
- Josh_Emerton
- Bobcat_GTS
Ozie wrote:its Air Pressure Compression lol. your ears pop, and it hurts your ears!
you can buy special side window vents for the Lancer, XxLaNcErGTSxX has them on.
this eliminates the Helicopter Sounds when traveling at speed.
I knew it was caused by air pressure fluctuations
Good to know about the vents. I was wondering if they would eliminate the problem.
- Phoenix
Tarquin wrote:Mattigins wrote:hell yeah! oi does anyone else smell burning when u have it on the hottest?
It is just a heating element, like a toaster, so if it's the first time you've cranked up the heat, I'd suggest you would smell some 'burning'....
But - like Josh said... wtf have you got he heat turned on...?
It's like 30+ C here atm..... LOL
interesting fact, i've never had my heater on, not once... lol! max was 22 or 23 deg.
Mah Ride: 2006 Hyundai Getz + 08 Lancer Bodykit
- Josh_Emerton
