taking off the side fenders?
- redlancer08
Does anyone knows how to take off the side fenders.?
Yes I know. What are you doing?
Want to know how?
1. Remove clips front wheel arch plastic.
2. Remove front bumper and headlight.
3. Remove the plastic corner but next to the side mirror mounts.
4. Remove the side indicator and unplug.
5. Between the door and fender, behind the fender is a plastic cover. Remove the clips and then you will pull the plastic around to discover a bolt. Remove it.
6. Remove the other bolts holding the fender on.
You're done.
Want to know how?
You're done.
- redlancer08
- redlancer08
Depends on the size of the dent...
Panel beaters could beat it out if not too big, and bog it up if need be. Then respray. If you were to buy a new panel, you'd have to get it painted anyway. Best thing to do would be to go visit a panel shop and get a quote. They'd tell you if they could beat it out or if they would have to replace the whole thing. And they could get a panel cheaper than you could anyway.
- redlancer08
http://www.ozeparts.com.au/
Their site is under construction ATM, but they have various parts and panels for the Lancers.
Users browsing this forum: Google [Bot] and 38 guests
