Thanks man! looks easy now! screw the on-with-the-doors thing
Cheap LED Lighting Thought.
- tadz0rz
Lol, i want to hook mine up to a relay or something so when im getting in the car or opening the door or whatever, they will come on, but as soon as i put it to accesories, they stay on all the time...Which is what will happen if you hook it up the way ive shown you. Unless you put a switch in the line...
Mine has a switch, a very hard to access switch because their actually on the cigarette lighter under the cupholder lol
- scraverX
Ah yes... that second accessory socket. Time to flex my electronics fingers I think...
Car & Home audio nut.
SIR-VRX wrote:It's a blue and black thin cable guys. in a white connector. Under the cup holder section.
The other harnesses under the pop-out pocket are for AFS (on the HID headlights, its steering lights) and AWC for the RA's AWD system.
are you sure they are HID in the Aspires and Evos, they don't look like they have washers. so if they dont then they cant be HID's well at least legal ones
- tadz0rz
They do blakey.
http://www.caradvice.com.au/wp-content/ ... -front.jpg
hard to see on black, but they are directly under the HID
