Side Skirts..
Side Skirts..
Does anyone know if the side skirts on the vrx/ra are the same length as the evo x's??
These could possibly fit non-turbo Lancer sideskirts. They bolt under the sideskirts (drill them in), no actual mounts for them so they can be positioned wherever (roof even if your up for it). The only one they wont be so easy to fit are ES without sideskirts.
I dont see why these wouldnt fit, they are only attached to the bottom of the sideskirt. They dont hook up to the sides or anything. You will need to drill them in. Pretty sure they dont even come pre-drilled.
Its like the front splitters you can get, huge piece of carbon fiber that you mount up yourself.
tjoz wrote:These could possibly fit non-turbo Lancer sideskirts. They bolt under the sideskirts (drill them in), no actual mounts for them so they can be positioned wherever (roof even if your up for it). The only one they wont be so easy to fit are ES without sideskirts.
its best to ask first.. as ive seen a few that have pre-drilled mounts..
