Ralliart in Tassie
Hoggy
Postby Hoggy » Tue Jan 06, 2009 7:20 am
Cheers Dan, good to know
Postby ofey » Thu Jan 08, 2009 12:56 pm
Sorry to hijack the thread like that but has anyone seen the rear panel (and have a picture) of our MMCS system. It's not the same as the US one but the folks in the US have a DIY installation of the Reverse Parking Camera which we could do for just over $200 instead.
ralliartas
Postby ralliartas » Thu Jan 08, 2009 3:44 pm
Here's a photo of the one the Mitsubishi dealer fitted to my Sportback ...
ralliartas
Postby ralliartas » Thu Jan 08, 2009 3:54 pm
And here's a (rather bad) photo of the MMCS with the rear camera in operation ... when reverse is selected the camera comes on ... the yellow line at the bottom of the screen is about as far as you'd want to reverse to .. and you can also see the top of the bumper (which doesn't show up in the photo)
Hoggy
Postby Hoggy » Thu Jan 29, 2009 10:31 am
Looks awesome mate. I am considering getting the camera, do you know where they mount it on the sedan?
bye2u
Postby bye2u » Thu Jan 29, 2009 3:51 pm
not sure if this is where they mount it for our aussie spec RA's but i remember going through some pics of RA's from japan and they are mounted dead center just under the mitsu logo.
SIR-VRX
Postby SIR-VRX » Thu Jan 29, 2009 7:09 pm
^^ Yes that is how the Aussie ones mount
Dummer
Postby Dummer » Thu Jan 29, 2009 10:01 pm
just remember that such a method of mounting will require a permanent hole to be drilled into you bonnet :shock: So if you live in a coastal area, prolly not a good idea as it'll be a perfect stop for rust to take hold...
Bandit
Postby Bandit » Thu Jan 29, 2009 10:30 pm
Doesn't look like they got it in the middle anyway..... looks a bit to the left of the diamond badge.
What about getting the reverse sensors instead HOGGY - they work very well on my car.
ClubCJ's first Sportback
SIR-VRX
Postby SIR-VRX » Thu Jan 29, 2009 10:35 pm
The_Bandit wrote:Doesn't look like they got it in the middle anyway..... looks a bit to the left of the diamond badge.
LOL you're right! It's off centre
Somebody FAILED. Hard.
Mizta B
Postby Mizta B » Thu Jan 29, 2009 11:00 pm
The camera looks a little out of place mounted like that anyway on the sedan I think
The reversing sensors would be a better option for me as I dont have the MMCS system in my car
Cheers Chris - mizta_b
Merlinised....
Bandit
Postby Bandit » Fri Jan 30, 2009 7:40 am
I got the sensors and they work a treat - can reverse anywhere with absolute confidence despite the fact that vision out the back window of the sportback is quite restricted.
DStutter
Postby DStutter » Thu Nov 26, 2009 11:13 pm
I've fitted an aftermarket butterfly style one to the rear of my sportsback. It fits just to the top left side of the rear number plate up under the plastic trim so you can barely see it face on. It looks great from the outside and you can still see the whole rear of the car. Parallel parking is so much easier with it. I'll try post some pics
BRE88N
Postby BRE88N » Sat May 12, 2012 9:16 pm
DStutter wrote:Ive fitted an aftermarket butterfly style one to the rear of my sportsback. It fits just to the top left side of the rear number plate up under the plastic trim so you can barely see it face on. It looks great from the outside and you can still see the whole rear of the car. Parallel parking is so much easier with it. Ill try post some pics
where abouts is the pics mate im about to do the same to mine thanks
Users browsing this forum: No registered users and 47 guests
