Widening Track with wheel spacers
draevon
Postby draevon » Tue Jan 19, 2010 10:41 am
I have a VR with Ralliart wheels. For mine they sit just a fraction too far inside the guards, so I was windering, has anyone experimented with using wheel spacers to widen the track on a CJ Lancer? I don't think it would need much, even 10mm/side would look better I think. Might end up giving it a shot anyways but just was wondering if anyone has heard of it being done on a CJ yet?
Tim
tadz0rz
Postby tadz0rz » Tue Jan 19, 2010 10:48 am
It would look better, but i believe adding wheel spacers is illegal...In melbourne anyway. Not sure of the laws in Brisbane..
Edit: Looks like it is..
Page 11 of 18 - http://www.transport.qld.gov.au/resourc ... icles2.pdf
The fitting of spacers or adaptors between wheels and
hubs, additional to those provided by the vehicle
manufacturer, is not permitted.
Not like they'd ever know or anything. Just as long as thought they dont foul the gaurds you should be okay
draevon
Postby draevon » Tue Jan 19, 2010 11:05 am
Oh yeah well ... I was talking about for offroad use only of course :)
blade888
Postby blade888 » Tue Jan 19, 2010 11:05 am
Also it would add extra stress and wear on your hubs and bearings, so you gotta keep that in mind too.
billyboy
Postby billyboy » Tue Jan 19, 2010 11:06 am
Maybe PM Taleb's see what they say?
Best to get the correct offset to begin with imho.
Chubb
Postby Chubb » Tue Jan 19, 2010 11:27 am
blade888 wrote:Also it would add extra stress and wear on your hubs and bearings, so you gotta keep that in mind too.
It is really surprising just how much extra stress is created by only a slight spacer.
draevon
Postby draevon » Tue Jan 19, 2010 11:38 am
Hmmm true ... ok ... idea shelved.
Chubb
Postby Chubb » Tue Jan 19, 2010 12:07 pm
maybe a bit wider rubber, would not have as much of an effect on the hubs and bearings.
bye2u
Postby bye2u » Tue Jan 19, 2010 12:29 pm
i'll probably be getting 10mm hub centric spacers in the rear for mine :D
draevon
Postby draevon » Tue Jan 19, 2010 1:05 pm
Yeah that's what I was thinking ... 10mm hub centric front and rear.
Blakey
Postby Blakey » Tue Jan 19, 2010 1:11 pm
getting spacers puts more stress on your hub , and your bolts that are in your hub. not to memntion you will either 1 have 2 sets of hub bolts or 2 have to cut your original ones so the wheel can fit on the spacers bolts. either way dont bother. buy bigger wheels if you really want them to be further out.
Return to “ClubCJ Talk”
