Bling Bling
30-35mm is what you end up with after about 2 months of driving. My ground-to-guard centre eyebrow heights are about 65cm.
Repco sells them for $270 (you can choose low rears or superlows. Superlows give you the flat look, lows keep the rear raised slightly).
I fitted them in about 2 1/2 hours, so cost neutral there and an alignment was $45. Cheap cheap at $315....
Good luck Deano.
Good luck Deano.
Users browsing this forum: Google [Bot] and 41 guests
