Warped discs @ 30,000km. Covered under warranty?
All Brake Modifications.
Postby turbogirl » Wed Feb 22, 2012 7:45 pm
I just had my 15k service on the RA and only had 20% wear which the dealer said was really good for RA but then i really only break to stabilise car or come to complete stop.
Do you have a automatic?? If so, your brakes will always wear faster.
I don't think they will replace under warranty, it's all about your driving style.
SXLancerMum
Postby SXLancerMum » Wed Feb 22, 2012 8:09 pm
Danese wrote:You might be able to get them repaired aye. Not sure how badly damaged they are. It cost you much less. I had the rotors on a CBR600 machined once, and they lasted a while after that. It might cost you around 50 bucks... not sure
Cost me $60 to get the Bubbles machined about a week and a half ago in Glen Innes.
Postby LZY_EYE » Wed Feb 22, 2012 8:28 pm
Mitsu disks are renowned for warping. It can be a bit hit and miss though.
If the mechanic you go to has on car disk machining it should be cheap. If they take the disks off and send them for machining it will probably work out more expensive.
Also check how much is on the pads, it is always a good idea to replace pads when replacing / machining disks so they bed together correctly.
SXLancerMum
Postby SXLancerMum » Wed Feb 22, 2012 8:32 pm
It's going brilliantly now. It sucks that the discs that were machined were only 12 months old though. Around 10,000km on them. They stuffed up a lot earlier though.
The last ones were way past machining. They were cracked.
Wonder how long it will last this time sighhh
Speedie
Postby Speedie » Wed Feb 22, 2012 8:47 pm
I've got 66000ks on my RA, original pads and rotors.
SXLancerMum
Postby SXLancerMum » Wed Feb 22, 2012 8:53 pm
Speedie wrote:Ive got 66000ks on my RA, original pads and rotors.
I hope the Lancer gets a few more ks out of her. She's sitting on 19,000. The Bubble got to 180,000. And then 190,000.
LaNcE
Postby LaNcE » Wed Feb 22, 2012 11:34 pm
had the evo's brakes machined. it was arounf 47000k's when i had it done. Its good to say what you have aswell as you dont do the brakes on the light which makes it easier on them. just to add my brake pads had atleast 3mm of material on them still.so it will last just depends on how you drive the car. and yea its 110% non-warranty item as its included in the wear and tear of the car. i asked last service.
SXLancerMum
Postby SXLancerMum » Thu Feb 23, 2012 9:15 am
The Bubble got its first set of new brake pads at 155,000 or so. New clutch at the same time. Then 25,000 later new rotors. Hmmmm that just shows what hardy little cars they are doesn't it. Pity the new parts are all shit.
Return to “Brakes”
