suggestion on brake pads and rotors
All Brake Modifications.
jason210493
Postby jason210493 » Sun Jun 24, 2012 8:59 pm
hi everyone, Im getting my car serviced next week and want to change my brake setup as well. i was wondering if anyone could suggest a good setup for brake pads and rotors? Cheers
Postby aspir3 » Sun Jun 24, 2012 9:36 pm
Try to get RA or VRX front brakes as they are bigger and better.
A few member here may have some VRX brakes for sale as they have upgraded to RA brakes.
jason210493
Postby jason210493 » Sun Jun 24, 2012 10:28 pm
thanks for the suggestion. I'm thinking of changing the brake pads and rotors for now, then maybe a big brake package later on. haha
megatron
Postby megatron » Fri Jul 13, 2012 4:48 pm
if you cant afford to upgrade to VRX calipers you are not going to be able to afford to upgrade to better pads and rotors
DBA 4000 series rotors and some QFM pads would be a upgrade
Postby ofey » Fri Jul 13, 2012 4:53 pm
The pertinent point is if you upgrade the calipers in future, your NEW brake pads don't just move over. You need to buy NEW PADs and in some cases NEW ROTOR as well.
Upgrade the BRAKES i.e. CALIPER & Pads + ROTORS in one hit.
darren1011
Postby darren1011 » Fri Oct 12, 2012 3:01 pm
I'm in the process of collecting parts to upgrade handling and stopping. I understand the Raliart rotors are larger, are they twin piston calipers? Will I need larger than the 16" wheels to cope, otherwise, i'm just going to get some new slotted RDA7646 @65 each and some better quality pads
mwang1990
Postby mwang1990 » Fri Oct 12, 2012 5:21 pm
The ralliart rear rotors cannot be used in a fwd car. The hub of the rotor is larger in diameter than the fwd brakes so the handbrake wont work.
Kal777
Postby Kal777 » Fri Oct 12, 2012 8:39 pm
DBA rotors part number DBA2201S for the front and DBA2209S for the back, i believe the pads are DB1441's for front.
darren1011
Postby darren1011 » Fri Oct 12, 2012 9:13 pm
Kal777 wrote:DBA rotors part number DBA2201S for the front and DBA2209S for the back, i believe the pads are DB1441s for front.
You think the DBA rotors are worth the 40 each difference? DB 1441 would be the Bendix number, I was told they give off abit too much dust to have a CAI and that QFM HPX would be better in terms of dust and equal in performance, also about 40 cheaper
Kal777
Postby Kal777 » Fri Oct 12, 2012 9:25 pm
DBA rotors are a lot better than RDA's in my opinion, they are made from a higher quality steel. also any slotted rotor is going to cause more brake dust no matter what the pad is.
darren1011
Postby darren1011 » Fri Oct 12, 2012 9:56 pm
Kal777 wrote:DBA rotors are a lot better than RDAs in my opinion, they are made from a higher quality steel. also any slotted rotor is going to cause more brake dust no matter what the pad is.
Thanks
darren1011
Postby darren1011 » Tue Dec 11, 2012 8:43 am
These arrived from the US this morning, full set zinc dipped slotted with ceramic pads, 300 bucks, off to see the wizard now, find out how much to install all this stuff.
Call me crazy but buying rotors in Aus seems to be a waste of money, at least so far, I might have been able to do the fronts for that much
darren1011
Postby darren1011 » Tue Dec 11, 2012 2:32 pm
TrojanHorse wrote:Nice one Darren. Yeah rotors do seem ridiculously priced here in aus...
The cheapest slotted RDA's I saw were 179 plus 30 for delivery, just the fronts. While I had to wait 3 weeks for these rotors, DBA is out of stock anyway so the shipping wait was irrelevant. Buying a CAI was easy too, about 320 delivered I think, 6 days it took. Service in this country sucks because there is no competition
darren1011
Postby darren1011 » Tue Dec 11, 2012 4:20 pm
http://www.ebay.com.au/itm/370632498184 ... 1497.l2649
R1 Concepts. I bought the Eline which is basic, htey have higher performance and black rotors, whicha are dearer
Return to “Brakes”
Users browsing this forum: No registered users and 77 guests
