Morning Lumps
Roadtrain
Morning Lumps
Postby Roadtrain » Mon Jun 30, 2014 9:40 am
I've noticed this twice now in the mornings when i start to drive, feels like there is a lump, faster i go faster the noise comes around, after about 20 mins or so its gone, anyone know what this is?
I thought it may have been tyres, but lump feeling goes away.
lantourismo
Postby lantourismo » Mon Jun 30, 2014 9:46 am
Lancers have been known to have noisey injectors, especially on cold start.
Roadtrain
Postby Roadtrain » Mon Jun 30, 2014 9:58 am
Im hoping thats all it is.
Port Macquarie Ralliarts
Mits
Postby Mits » Mon Jun 30, 2014 12:37 pm
As mentioned above the lancers (pretty much all from factory) have noisy injectors. Nothing to worry about if this is the case.
Roadtrain
Postby Roadtrain » Mon Jun 30, 2014 1:01 pm
Thanks Hoges, I still do hope its nothing to worry about or a simple fix at least.
thanks again.
R4LLI4RT
Postby R4LLI4RT » Mon Jun 30, 2014 1:21 pm
if u 'feel' bump/lump while your driving id get your wheels re-balanced
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
Roadtrain
Postby Roadtrain » Mon Jun 30, 2014 1:45 pm
R4LLI4RT wrote:if u feel bump/lump while your driving id get your wheels re-balanced
only for the first 20mins or so, the rest of the day is fine would it still be a wheel balance issue?
R4LLI4RT
Postby R4LLI4RT » Mon Jun 30, 2014 2:23 pm
i can only assume this
rubber heats up and then the bump is softer
ask to swap wheels with some1 (if u know some1 that is) and then go for a drive
DBA Extreme Pads
Tein S Tech Springs
Roadtrain
Postby Roadtrain » Mon Jun 30, 2014 2:49 pm
Aha Valid point R4LLI4RT , i haven't driven the car since 8am today and probably won't again till around 5pm, should be cold again and see how we go :D.
R4LLI4RT
Postby R4LLI4RT » Mon Jun 30, 2014 2:57 pm
if its not that then you need to look at wheel bearings maybe a hub needs replacing
DBA Extreme Pads
Tein S Tech Springs
R4LLI4RT
DBA Extreme Pads
Tein S Tech Springs
R4LLI4RT
DBA Extreme Pads
Tein S Tech Springs
Roadtrain
Postby Roadtrain » Mon Jun 30, 2014 3:11 pm
Gah will start with the wheels and go from there.
Thank you
el3ment
Postby el3ment » Mon Jun 30, 2014 5:16 pm
If its wheels... roll down a hill and go into neutral or whatever so you cannot feel the lumping... if its the tires, it will still do it with engine idling...
