Hi.
The display in the rear vision mirror comes on when the vehicle goes into reverse. Can anybody tell me please how I can turn this screen on manually? I'm assuming there's a switch or the like that I can access.
And in case you are wondering... just because I can (hopefully). No other reason.
Cheers,
Greg
Rear vision mirror camera
Wire a 3 way switch in it.
Find the wire that gets the signal from the the reverse gear leaver to to mirror. Cut it in half and wire the switch in it.
Then put on one of the wire that has power when acc is on.
Then one with the OEM wire going to it and the other as the off switch (the other side that you cut in half)
Then you can flick between manual, auto , Off
Love That Car.
Hi.
Thanks for the idea - youre quite right - that would work well.
After a lot of to-ing and fro-ing, I managed to get a schematic from Mitsubishi, so if anybody wants it, please find me here.
Cheers,
Greg
Cheers,
Greg
- lantourismo
Users browsing this forum: No registered users and 57 guests
